I was doing a coolant flush. Removed nuts from water pipe to pull it up since it was in my way for the bottom bolt (no wrench because PO cross threaded bolt) Tapped threads clean and when I went to refill with my Cascade mix, it was CASCADING down the front of the block until it got enough to build pressure, then began to spray. Where does this pipe go to and is there any way to fix it? Hoping I didn't deform the ends that I'm guessing interference fit into the block.
HELP! I need the car in 14 hours for work!
