Originally posted by RhodeStiva
Coolant leak from hard pipe on front of block... what do I do now!
I did what Rhodestiva suggested, and it worked great, but now I sprung a new leak further up the line. I have another idea, tell me what you think, what it you ran a rubber coolant hose from that joint by the outlet pipe all the way behind the manifold, get another heat shield from a jy, put it over the rubber coolant hose that runs behind the manifold. Do you think that it would block the heat and keep the hose from melting?Last edited by Breedlove; 09-12-2013, 07:53 PM.93 Festiva GL
I'm kind of chicken, I am too afraid of it overheating and jacking the heads, I'm just bouncing ideas of people.Originally posted by jason_ View PostJust try and post results. Only way to know. Anyone can guess at anything anytime.
Sent from my rooted HTC Supersonic using Tapatalk 2 ProLast edited by Breedlove; 09-12-2013, 09:02 PM.93 Festiva GL
Not for long. Run your Festy up a long hill at night, jump out and look at the red manifold glowing like Rudolf's nose.Originally posted by Breedlove View PostI did what Rhodestiva suggested, and it worked great, but now I sprung a new leak further up the line. I have another idea, tell me what you think, what it you ran a rubber coolant hose from that joint by the outlet pipe all the way behind the manifold, get another heat shield from a jy, put it over the rubber coolant hose that runs behind the manifold. Do you think that it would block the heat and keep the hose from melting?Red Rocket 1988 L, 133,XXX miles, 4 sp. AC, hit guard rail in snow, RIP, saved everything but body
Black Rocket 1988 L 207,XXX miles, 4 sp. AC, engine, trans, wire harness, radiator from RR
Red Rocket 2 1988 L 138,XXX miles, 4 sp
White Rocket 1989 L 128,XXX miles, 4 sp. AC
