ok, so i get there. and the car is fi...BUTTTT the interior is immaculate. light blue lined interior, panels are great, seats are in great shape. so im still kinda stuck on the carb deal, but ill have a close to new interior soon.
engine idle problems.
save it!!!! resurect that Festy! you could always swap the EFI system over to your chassis if you can't put that 90 back on the road.... (not as bad as you think, especially if you're doing an interior swap)Trees aren't kind to me...
would this work with an adapter?
also found this, http://www.partshotlines.com/?phl=se...ch_id=36323108
but im not sure its worth it..Last edited by txranger14; 05-18-2013, 12:45 PM.
Get this one,its jetted very cclose to what your engine needs
YupTrees aren't kind to me...
Do a search on "Weber adapter".90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
How hard is it to do the swap. I'm having the same problem and I did have the carburetor rebuilt but I had a buddy that is a mechanic he did it for free but I'm still having the same problem so I would like to know where to go from here as well should I buy the escort carb or figure out if there's another problemOriginally posted by bravekozak View PostBe sure to get the intake manifold that is in the works. Get rid of the computer controlled feedback carb. What a headache trying to figure out what's wrong.
Mine did exactly the same thing before I Weberized it.
Ditch the old carb. Do not rebuild it. It's not worth even one cent.
Put on a non-computer controlled Escort carb.
Someone help me. Is this a good one?
Sent from my SGH-I747 using Tapatalk 2
got the little bastard. took me a while, but it came out. the wire to the alt and two harnesses came out with it. im assuming i will have to save those and re use themLast edited by txranger14; 04-17-2014, 08:10 PM.
Justin, the Weber carb requires 12 volts to operate the choke, the wire from the alt for the feedback choke is only 7 volts.
When you install the weber, use one of the old sensor wires, that is "key on" 12 volts, and use that for the choke.
You need only that and one vacuum hose for the disty, which you run from the carb vacuum port and you can tee to both vacuum ports on the disty.Dan
