The gear in the pump that engages the converter can crack. Looking straight in from the front you should see it. You will probably see some circular rub marks that you need not worry about.
Torque convertor install
Its from the flex plate pushing it in, to much inward force without being through the hole can crack it. Unbolt it and put it in again, it needs to go in another 1/2 inch or so. You can feel it go in the bushing, you can feel the splines engage and last of all the pump drive lugs. It will make a solid thud when it hits the end.Reflex paint by Langeman...Lifted...Tow Rig
