Afraid I may have screwed up mounting wing on wife's car.
  • Afraid I may have screwed up mounting wing on wife's car.
    I tried using expanding rubber plugs, used 1/2" holes. Somehow I got the wing a bit too far forward and it hit the roof and pulled the front plugs out. Not sure what to do now.
    ouch!,,,,weld in patches and redo.
      Seems like a hatch swap and repaint might be easier.... I've tried welding on this thin metal and it's tough.
        I think I figured out a solution. I'll cut out oversized sheet metal patches and tape them down. Then I'll position the wing and tape it down and make sure it clears (didn't dawn on me to do this before). Mark the holes with the drill and pull them off and finish drilling them, then weld a nut on the back and weld them in place.
          Sounds like a lot of work, just sell it to me, problem solved.
            Of course you'll want a discount due the the messed up holes in the hatch....
