I was doing some work on my carb today. Specifically I was checking out the choke unloader. The repair manual has you open the throttle fully, hold the choke closed (w/o forcing it), measure the gap between the choke plate and the wall, and bend the tab on the choke unloader to adjust. Well, the problem is that the choke closes completely, and when I go to adjust it won't stay open. As soon as I remove the allen wrench I was using to check the gap, the choke closes again. I'm wondering if the choke lever is a little loose or the spring has worn out. Everything else checked out fine.
Also, because I know someone is going to mention this, but a weber conversion is out of the question. I can't afford it.
