Fuel pump not getting electricity?
  • Fuel pump not getting electricity?
    Today my car festy died on the way home. My initial thought was that the fuel pump had gone out. After trying a different mass air flow sensor and fuel pump in it and testing the ones that were in it on another Festiva I can safely say that the fuel pump and sensor are in working order. So now I'm trying to figure out what to check next.
    The fuel pump is working in the other festy but is not sending any fuel when I have it in mine.
    My Fuel Log
    The relay? it's black and yellow, On my protege it was down behind the center console with the ecu.
    Owner of:
    In progress:
      You didn't test by adding fuel?? Or checking for spark?
        I'll look in the manual for the location on this.
        It has 3 quarters of a tank and is getting plenty of spark. I have had 3 different fuel pumps in it and the one i had in it before is confirmed working.
        My Fuel Log
          also test relay under hood by radiator overflow and battery i had that go bad and i got no fuel.
          www.facebook.com/rhodestiva ;
          rhodestiva@gmail.com ;
          '92 Festiva L M/T
          '93 Festiva GL A/T
            Have you tried resetting the Inertia switch behind the driver side rear panel in the hatch??
            2008 Kia Rio- new beater
            1993 Festiva- Fiona, DD
            1997 Aspire- Babyspire, DD
            1994 Aspire - Project Kiazord
            1994 Aspire- Crustyspire, RIP
              I tested that with a working one and still nothing.
              never heard of it. I'll check into it and report back.
              My Fuel Log
                there is no spark going to the coil, so I tested the positive/negative and the positive on the electrical input isn't getting power. Not sure what's causing it..
                My Fuel Log
                  In the end it was a bad coil... so much for trusting someone else to verify no spark in the middle of the day in full sun. thanks for the suggestions anyways lol. Now i'll know steps 1-5 if it happens again : /
                  My Fuel Log
