I have little to no acceleration when in any gear. It's slow uphill, barely making it and barely goes over 50mph. The rpms run high in each gear as well. Please help
Little to no acceleration
^ could be an auto.... in either case i would look at a clogged cat (lack of power).
angelanblair, if you could provide more info about your car, that would be helpful.Trees aren't kind to me...
I will go with what everyone else is saying, it does sound like a clutch.
Never heard of such a problem for an automatic.1991 Ford Festiva BP (Full Aspire/Rio Swap) (337k Miles) (Around 95k Engine)
then you've never driven an auto with low fluid..... or a bad pumpTrees aren't kind to me...
Originally posted by FestYboy View Postthen you've never driven an auto with low fluid..... or a bad pump2008 Kia Rio- new beater
1993 Festiva- Fiona, DD
1997 Aspire- Babyspire, DD
1994 Aspire - Project Kiazord
1994 Aspire- Crustyspire, RIP
Originally posted by zoom zoom View PostYea that's usually my problem, like today going to work and back...second time I've driven the spire since I bought the Festy. Turned out my wife neglected to check the fluids for the last 3 weeks or so!!!Reflex paint by Langeman...Lifted...Tow Rig
I guess that would make sense though, since an automatic just will not function well at all without enough fluid, considering that the fluid is much more important in them than say a Manual. A manual will function without oil or fluid, but it won't last long obviously, but an automatic without fluid won't function at all.1991 Ford Festiva BP (Full Aspire/Rio Swap) (337k Miles) (Around 95k Engine)
