i was driving down the road and my engine cuts off it gets spark fuel and turnsbanana time over but wont start could it be the timing belt
89 wont start
I would guess the timing belt didn't break. It MAY have skipped a tooth or 3.
If you're getting a nice steady rhythmic spark while trying to start then belt didn't break.
Some other info that may help to diagnose.
Fuel injected or carbed?
What color is the spark?
I'm sure there are other questions, but these are a starting point.
Others with a bit more knowledge will more than likely chime in also.
no injector control (given the statement that you have fuel, meaning fuel pressure.... otherwise look at the fuel pump).Trees aren't kind to me...
And check the plug connection at the VAF. This can keep you from getting fuelLast edited by nitrofarm; 05-19-2013, 12:22 PM.Some people like to read fiction,I prefer to read repair manuals. Weird I know-
I had a Zephyr that did something similar to that occasionally, and usually at high speed on the Washington Beltway....very scary! Turned out to be the Electronic Module.....when it heated up, it quit, when it cooled down, the car would start and run till it got hot again.Originally posted by airlock View Posti was driving down the road and my engine cuts off it gets spark fuel and turnsbanana time over but wont start could it be the timing belt
hth
Chuck, CABGx3
^ haha no...
since you have EFI, finding the issue should be rather easy, especially since you have spark!
open the hood, go to the driver side strut tower and look for a loose 2 wire connector in the shape of a T (it should be black). take a paper clip and jump those 2 wires. turn the key to the RUN position, you should hear the fuel pump run. if you don't, you need to verify that you have power to the pump by flipping the rear seat all the way forward, flip the carpet forward, remove the pump access cover, and checking for power at the 4 pin plug on your pump housing (use a multi-meter).
post results and further instructions will commense.Trees aren't kind to me...
weak spark is a coil issue, not ICM
Inertia switch is below the driver rear speaker
how do you test for fuel? have you jumped the test port? (located driver front strut tower, t shaped, black, 2 pin connector)Trees aren't kind to me...
