coil has great spark pulled fuel line off and it shot fuel across the yard good fuel
89 wont start
so what you're saying is you have a pickup issue.... pickup runs signal for spark and the injectors. does the VAF make the pump run when manualy operated?Trees aren't kind to me...
with key on, push VAF door in, fuel pump should run, confirm.Trees aren't kind to me...
I told you earlier, the ICM doesn't control strength of spark, only when it happens. go after your COIL.Trees aren't kind to me...
