Zoe, the buck you felt is primarily from your accelerator pump jet. and i suspect there's an issue with your vaccum advance on your dizzy. the reason you feel it primarily when shifting is because you're attempting to accelerate once in gear and that press of the pedal causes the accel pump to squirt fuel, where when you're pullingout in first, you're feathering the pedal and NOT inducing accel pump activation.
a stumble at steady speed could be ignition timing, or fuel delivery (lack of fuel pump volume). the other option could be a rich miss (too much fuel for the amount of air being induced) from an over active secondary OR poor float pintle sealing (bowl too full).
