Transmission trouble
  • Transmission trouble
    Anyone know of anybody in the central North Carolina area who would rebuild a 5-speed manual transmission for a Festiva? I think the the ring gear went out on mine. Raised it up on jack stands, one wheel will turn but the other just moves jerkily. Makes a rattling/grinding noise too. Called a few places, but most don't want anything to do with it. Thanks for any help.
    You might want to pull the driveaxles out just to make sure the problem is not within those.
      Med man, you might want to refine your location.
      North Carolina is a large state.
      If we have a better idea of where you are, we might know someone close.
      Otherwise, we are talking shipping and/or some one make a long drive, possibly when someone else is nearer.
        this is screaming "bad spider gears" to me (common failure in the E series trans when abused)
