transmission noise
  • transmission noise
    I just started driving home from work and the transmission is making a rubbing/scratching noise only when under a load... noise goes away going down hill. Please advise
    Where do you check/add transmission gear oil? It is a 5 speed
    10mm nut on the speedometer drive gear on the back of the transmission, wiggle the tab back and forth until the gear pops out of the transmission, don't force it you'll break it.
    2008 Kia Rio- new beater
    1993 Festiva- Fiona, DD
    1997 Aspire- Babyspire, DD
    1994 Aspire - Project Kiazord
    1994 Aspire- Crustyspire, RIP
      Also , there is a vibration when it is making the noise
        I'm thinking that when it is under load, it is torquing a bit and rubbing against something. Look around in the engine bay and under the car to see if you can see any rubbing. May be a broken motor or tranny mount for example.
          I have heard noise like that before and it ended up being my alternator grinding.
          www.facebook.com/rhodestiva ;
          rhodestiva@gmail.com ;
          '92 Festiva L M/T
          '93 Festiva GL A/T
            Well, I made it home but definitely think it is the transmission!
            Which is a better manual, the Ford or Haynes?
              ford FSM FTW
                What does Ford FSM FTW mean?
                  Ford Field Service Manual for the win. But get the Haynes too, at any McParts store.
                    Could a bad CV joint/axle make noises like this?
                      yes.
                        UPDATE****Jacked it up, took front tires off, cranked it up, put it in gear and let out on the clutch. Left front hub barely moving, actually I can hold it still while the car is in gear idling. Any ideas what this could be?
                          ^ that's the open diff working.... totaly normal.
