I was wondering what it could be and wanted to get an idea before i started ripping things apart. Erika is my only car at the moment.
So sometimes when im driving slow, like coming to a light there is a popping sound that can be felt through the brake pedal. As the car slows the popping interval slows.
It is super noticeable when i am applying the brakes and doing parking lot type of maneuvering. I read it could be the inner tie rod or the brake disk hardware. My cv joints have about 10 k on them so im thinking its not them. The pop is also way to slow to be that.
Any thing else i should look for?
so I have to replace that one next but its all good now that I thin k I know whats up. Hope this helps. Check it out veggie you start tearing the whole assembly apart. The bolt well have some weare on it if this is the case. It doesn't have to be much, when it comes to suspension and the knuckle stuff a 32 of an inch matters
