So I just did the LCA on both sides. New rotors, New pads, new bearings, and the calipers are new as of february. Bearings are timken, calipers are stock remans, pads and rotors are duralast oem replacement.
As far as I can tell the calipers arent stuck. The bearings are slammed with Mobil1 synthetic grease, New seals, everything is torqued to festiva manual specs.
Why would my steelies be getting hot?
Its only the front (both sides), rear is fine.
I drove it for 5 minutes and the wheels were warmer than they should be. I did no hard braking other than starting out to make sure the brakes stopped bumping (which I originally felt in the pedal)
Help please? !
Sent from Galaxy S4 TAPATALK2
Help please? !
