Could also be your alignment. Too much friction on the tires heating up your rims. Thats whats happening to me. Did you do an alignment after all your work of ripping the brakes apart?
Wheels are getting hot?
Im actually going tomorrow and having alignment done. Toe in and out is all that will be able to be done (to my knowledge) as in previous alignments the front and rear caster and camber have no adjustments according to the Hawk-Eye alignment machine.Originally posted by jesteratc View PostCould also be your alignment. Too much friction on the tires heating up your rims. Thats whats happening to me. Did you do an alignment after all your work of ripping the brakes apart?
Sent from Galaxy S4 TAPATALK2Est. 1989 "Bringing laughter and festiva awesomeness to the world since birth" banana time
Frank its not your alignment I'll bet a case of Imports on it. Its your bearings,you said you are missing a spacer. Its a no brain er. No spacer equals mass quantities of bearing pre load. Factory pre load max is basically .0015". With no spacer the axle nut is just squeezing the bajeebers out of the bearings giving lots of friction. If you are missing a spacer on one side,Murphy's law dictates the other side is Bogus as well. If Bert has parts for you & will GIVE them to you,jump on that and pay the shipping.Then rebuild them and dont mix up the spacers.Last edited by nitrofarm; 06-09-2013, 08:30 AM.Some people like to read fiction,I prefer to read repair manuals. Weird I know-
Thanks!!Originally posted by nitrofarm View PostFrank its not your alignment I'll bet a case of Imports on it. Its your bearings,you said you are missing a spacer. Its a no brain er. No spacer equals mass quantities of bearing pre load. Factory pre load max is basically .0015". With no spacer the axle nut is just squeezing the bajeebers out of the bearings giving lots of friction. If you are missing a spacer on one side,Murphy's law dictates the other side is Bogus as well. If Bert has parts for you & will GIVE them to you,jump on that and pay the shipping.Then rebuild them and dont mix up the spacers.
@Bert hook me up man. I'll pay shipping. Pm me.
Sent from James' Galaxy S4 TAPATALK2Est. 1989 "Bringing laughter and festiva awesomeness to the world since birth" banana time
^ same here... missing preload spacer is a death warrent for the bearings.
and the axle nut torque is 116-186.... i dont run any more than 150....Trees aren't kind to me...
