Tried to take the MTX dipstick out today to check fluid & add ZMax. I could not get it out of the trany. Yas I removed the speedo cable & the screw that holds it. It would not budge,I even gentley bumped it with a rubber hammer. Any ideas or hints?
MTX dipstick/speedo gear
Whenever I have one that's troublesome I shoot a little PB Blaster around the seal and give it some time to soak down to the o-r-ring. Then I take a large open end wrench that fits the flats of the mounting tab and gently rotate the housing a few degrees in each direction until it loosens up. I can't remember the exact wrench size I use....maybe a 19mm? You can use a large adjustable too but I prefer a thinner standard wrench since that's a tight area.
Channel Locks or pliers will work too but you risk chewing up the edges of the mounting tab if you have to get heavy handed with it.Last edited by Zanzer; 06-13-2013, 07:28 PM.
Twisting motion is what you want in order to break the seal. Mine readily come out now but I do recall the first time around was a chore. You should be able to reach in from up top (rather than getting under the car) with a pair of vicegrips or some such and wiggle and twist until the sucker comes loose.
got the speedo gear/dipstick out. Fluide was very low, add ATF fluid & 6oz bottle of ZMzx Trans Formula, BUT I broke the tab that locks the gear/dipstick in place!!! I broke it with my hand as I was twisting the part back and forth. Anyone got an extra for sale?
