First a short back story. (so ya know what i'm dealing with)
Festy had air when I got it (dealer install?) It was rigged with a toggle switch on the dash for it to work. It ...kinda...worked.
Summer before lest, belt bunt up and blew off. Assumed it was the comp. Turns out it wasnt, the idler had locked up!
Trying to get get it all to work again, got a new idler, new belt, but here comes the issue with the rig that was done to it.
I had removed the wire that went to the toggle switch, and I THINK, went to the compresssor? Dont know how the guy had it rigged, and I know nothing about AC except, what I read in Haynes and searched here
But! .... Here are pics of what i'm dealing with! (pics = good!)
I have this CUT wire coming from passenger side harness, behind headlight, looks like it could go to the compressor????
....and this wire coming from off the compressor (has a crimp style connector on it) maybe where the rig was going to??
wondering if the 2 wires originally went together?
I have tried checking with a multimeter the voltage at the cut wire, that has the red sleeve on it, and no power there, with or without the inside dash ac contol fan, on or off.
The light on the inside ac control does light up when the fan switch is turned on, and the rad cooling fan comes on also.
Thanks in advance!!!!!!!!!!!!!!!!!
