Gas leak?
Only getting 20 MPG?
NopeOriginally posted by denguy View PostGas leak?;
www.facebook.com/rhodestiva ;
rhodestiva@gmail.com ;
'92 Festiva L M/T
'93 Festiva GL A/T
Before it was at 3000 rpm now after timing fix it is at 2500.;
'92 Festiva L M/T
'93 Festiva GL A/T
Well that should help!
'92 Festiva L M/T
'93 Festiva GL A/T
What's idle rpm?2008 Kia Rio- new beater
1993 Festiva- Fiona, DD
1997 Aspire- Babyspire, DD
1994 Aspire - Project Kiazord
1994 Aspire- Crustyspire, RIP
800-900;
'92 Festiva L M/T
'93 Festiva GL A/T
What was at 3000RPM? It was running 3k at 65, now its running 2.5k at 65? That doesn't add up unless you changed tires, trans, or your clutch was slipping before...Originally posted by RhodeStiva View PostBefore it was at 3000 rpm now after timing fix it is at 2500.Last edited by htchbck; 07-31-2013, 01:29 PM.No festiva for me ATM...
yes and i changed my timing it was off a tooth.Originally posted by htchbck View PostWhat was at 3000RPM? It was running 3k at 65, now its running 2.5k at 65? That doesn't add up unless you changed tires, trans, or your clutch was slipping before...;
'92 Festiva L M/T
'93 Festiva GL A/T
I bet your timing is still out, mine gets really bad milage when the distributor isn't set right...like it is now. I'm tempted to take my next $70 to a garage and have them guys do it to see how far off I am.2008 Kia Rio- new beater
So you changed tires? That will definitely help with highway mileage if its giving you a lower cruising RPM. From reading that it sounded like the only thing you had changed was timing, which shouldn't affect cruising rpms at all, just idle.Originally posted by RhodeStiva View Postyes and i changed my timing it was off a tooth.No festiva for me ATM...
$70 will buy you a pretty nice timing light...just sayingOriginally posted by zoom zoom View PostI bet your timing is still out, mine gets really bad milage when the distributor isn't set right...like it is now. I'm tempted to take my next $70 to a garage and have them guys do it to see how far off I am.
what you're describing is not possible without changing a gear ratio. timing wont change engine RPM for a given gear and speed, and tires won't change it THAT much (16.7%). something else is suspect there.Originally posted by RhodeStiva View Post
Before it was at 3000 rpm now after timing fix it is at 2500.Trees aren't kind to me...
It doesn't add up, I'm with Arty and htch on that one, fixing the timing will help power and mileage, changing to a larger tire can change mileage either way, depends on tire and that could change the tach and speedo readings altho the speedo is suspect until GPS verified. The mpg and odo are suspect until the odo is verified.Reflex paint by Langeman...Lifted...Tow Rig
