Hello everyone i recently been hearing rumbling clicking noise near alternator along with oil shooting through car because of either worn rings or clogged ports somewhere according to backyard mechanic he said engine might be going bad but i don't think so he said to take off valve cover clean out with diesel and replace oil,rinse and repeat to unclog anything. me and my dad took off valve cover cleaned upper pcv ports and head put it back on and started it it ran good turned it off and not its not starting anymore battery seems fine not sure if its the alternator gonna check it tomorrow. its turning over but not starting and charge light is on wanted to get your guys suggestions i really dont want to get rid of car i love my festy and have been trying to slowly fix it up but getting frustrated any help,suggestion ideas will be appreciated.
festiva not starting help!!
First, is it efi or carb? Makes a difference what the problem might be. The oil issue sounds like blowby. If you think alt is bad, have it tested. Its free at most auto part stores.
Washing with diesel sounds like he was trying remove built up sludge from the valve cover. There are "baffles" under the VC that supposed to catch the oil mist and stop it from getting out. Sometimes the baffles get clogged and dont do the job.Last edited by drddan; 08-06-2013, 01:31 AM.Dan
What did you take loose, any wires? Think if you put everything back. Most batteries I've had go bad died slowly, not instantly, though they can. I had a battery that tested bad still start my car and run fine because the starter is relatively small. It sounds like you could have a loose alternator/belt, bad solenoid, wiring connection (ignition switch,fusible links). Make sure your battery terminals are clean and tight at the battery, solenoid, and ground bolt.When I'm good I'm very, very good and when I'm bad I'm HORRID.
Check to see if you have spark at the spark plug end of your wires. Pull a wire, have someone crank it, hold wire close to spark plug or block while cranking, and see if you see a spark.Originally posted by goldenmean View Postits carbed and yea we cleaned the sludge out of baffles not a whole lot tho. i will have alt tested tommorow but if its good what other suggestions would you have dr dan??
The ICM inside the carb disty is a known culprit for failing. No spark= bad ICM ..... Spark= good ICM
ICM's can usually be had on ebay for under $50.
If you have a no spark condition and it is the ICM...it is easily changed.
ICM removal:
1)Pull disty cap and rotor out
2)Pull 3 wires from the terminals on the ICM (half moon shaped black plastic thing)
3)Remove 2 screws holding the ICM to disty
4)ICM comes out by sliding it sideways out of the disty. DO NOT PULL UP ON IT!
... If you are say, on a bench with it, and holding the disty with the top rotor side up, you will need to slide it out sideways, and up over the round body of the disty.
The 2 little tabs as seen here is why it needs to slide sideways.
If you have festy's in a junkyard near you, you can do what I do...pull the ICM out of the disty! Takes like 2 minutes!Last edited by drddan; 08-06-2013, 11:59 AM.Dan
Any members in NJ who can go over and look at this?90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
TominMO, I now know who hit the speedway yard in IL!Originally posted by drddan View Post
If you have festy's in a junkyard near you, you can do what I do...pull the ICM out of the disty! Takes like 2 minutes!'93 Blue 5spd 230K(down for clutch and overall maintanence)
I was thinking that too.Originally posted by Pu241 View PostTominMO, I now know who hit the speedway yard in IL!90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
