U
escort gt swap no HP!!
www.facebook.com/rhodestiva ;
rhodestiva@gmail.com ;
'92 Festiva L M/T
'93 Festiva GL A/T
Does the ecu need to be mounted so it has a ground because mine is not.;
'92 Festiva L M/T
'93 Festiva GL A/T
the chassis should be grounded, but there should also be enough grounds through the harness as to not REQUIRE the chassis to be grounded.Trees aren't kind to me...
in my experience NO, I drove Festycul around for a few months with the ECU just hangingOriginally posted by RhodeStiva View PostDoes the ecu need to be mounted so it has a ground because mine is not.Barbie Car - '90 L-plus_2nd Gen SOHC B6+rear turbo @ 8 psi
i might have a miata ecu in. that could be the only thing left to check.;
'92 Festiva L M/T
'93 Festiva GL A/T
Would not having the iacv plugged mess it up? And I will check the numbers when I get home.;
'92 Festiva L M/T
'93 Festiva GL A/T
iac controls cold idle ONLY. having it plugged will not affect the power in any way.Trees aren't kind to me...
ok thanks;
'92 Festiva L M/T
'93 Festiva GL A/T
The ecu came out of a 90 323. BP01Last edited by RhodeStiva; 08-13-2013, 04:56 PM.;
'92 Festiva L M/T
'93 Festiva GL A/T
323's had BP's?Originally posted by RhodeStiva View PostThe ecu came out of a 90 323. BP01Barbie Car - '90 L-plus_2nd Gen SOHC B6+rear turbo @ 8 psi
The one I got this from did.;
'92 Festiva L M/T
'93 Festiva GL A/T
You can't read the numbers at all I just wrote down with a sharpie on the ecu when I pulled it. And I only pull BP ecu so assumed that was the number but with further looking that's couldn't be it because that is for a sohc. So disregard the number. But it did come out of a 323 and it had a protege BP so I assumed when I pulled it it would work. I am goin to the JY on Friday to find another.;
'92 Festiva L M/T
'93 Festiva GL A/T
