how in the hell did i do that??
  • how in the hell did i do that??
    Hey guys I ran into a alittle stumper today I took out my 1156 silvania bulbs an put in reg 1156 bulbs (cause I got pulled over for a tail light out) an now when I hit the brake my my little running lights runnin lights come on in my headlights huh??? How the hell did I do that? Help please..
    P.s. my fog lights r wired to them as well so it looks like I'm flashing someone when I'm coming to a stop lol
    Frankie
    fully custom 88 festy (project doomsday) Febuary in 2012 calander
    Blockspire: ken block replica aspire
    AdvancedDynamix: "If you put the same kind of effort into your engine that you put into the rest of the car, well... it'll be epic". thanks man
    http://www.facebook.com/#!/profile.p...00000110128487
    First of all, if you did something and immediately got a bad result, suspect what you just did. I have to make some assumptions here: (1)you're talking about an 88 Festiva (2) when you got pulled over, it was actually for a *TAILLIGHT* bulb. The taillight/brakelight bulb should be an 1157 two element bulb. The 1156 is a one element bulb. The contacts are probably making wrong connections to give feedback in your lighting circuits that should not be there, because something sure is.
      It's on an aspire. i say this cause he said the little running lights in his headlights. those lights are wired to the park lights, which would explain why when you changed the rear, those come on. i'd check for corrosion in the bulb socket in the back. my aspire i used to have did this same thing and it was just a bad connection back there. good luck
      1990 Festiva L "puddles". 187,000 mi. All stock, B8 coming this fall to a festiva near you
      Do not write below this line; for office use only
        Well I found out its the rear driver side causing the issue cause when I changed back to the more expensive bulb is stops the problem up from an yes I'm talkin about the aspire
        Frankie
          Junk bulb shorting out. if they got messy with the wire inside it could cause that. i had a fog light bulb blow my fuse once because of that. napa gladly gave me a new bulb and fuse. lol.
