Replace oil pump or not
    One thing for sure, it always gets plenty of lubrication.
      Originally posted by logan View Post
      How do I go about priming the old pump when I put it back in?
      Pull plugs, kill fuel and ignition, grind on the starter for 20 seconds. Or at least until oil light comes off, or gauge moves. Bump key a few times to see how long pressure bleed off takes place after pumping stops.
      I always nod to myself with satisfaction after I stop cranking engine, taking a full 2 seconds before light turns on. Of course 15w40 is cheating on tight bearings and room temperature.
        Dumb question how do I kill the fuel and ignition?
          Pull a few important harnesses on coil/dist, undo a fuel line? Pull a relay, more the one-way to skin a cat.
            dont have to do that, just jump the battery wire at the starter to the starter signal wire and boom, you have a cranking, but non-running engine, all while everything is hooked up correctly!
              Always coming up with cool, easy, ways to do stuff arent ya! :razz:
              Dan
                Just in case, I want to say put oil in that pump, better not to crank it dry.
                  Mine sucked oil when it was dry. Well, not "dry", but you get my point.
                  It took prime. I just poured a capful before setting gears and cover together.
                  • #24
                    A remote starter button works well for this too
                    WWZD
                    Zulu Ministries
                    • #25
                      well YEEAAAHHH but not all of us have those handy dandy fancy dancy tools, LOL.
                      • #26
                        ^^ Hahahaha! C'mon man! It's like 10 bucks at Harbor Freight! LOL
                        WWZD
                        Zulu Ministries
                        • #27
                          why spend $10 when you can use a screwdriver!? lol
                          • #28
                            Says they guy who was giving me crap for not using noid lights LMAO :mrgreen: You're killin me man LOL
                            WWZD
                            Zulu Ministries
