Has anyone opened an ECA to see if there is a removeable ROM chip as was common on older computers? - otherwise, why would they seem to all have the same part number, as I was told? I would like to know what is interchangeable if the ECA goes bad.
ECA - ROM
If I remember correctly the B3 ECU that someone handed me at Ohiostiva last year(?) did NOT have a ROM in it. If I run across it I'll double check.
It was hit or miss with the ROM's
B3=no?
B6D=yes
B6T=yes
BP=no
BPT=no
not sure about the SOHC's, I wanna say the SOHC B6's had ROM's. Depends on the year too. Some of the early (86,87?) euro spec B6T ecu's were not equipped with a ROM whereas the later ones were.1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
Rocketchips!
Bolt-on Weber Carb Adapters!
