I have -89 carbed 121, wich has few wierd problems, first problem, it just dies when rpm's drop to idle, this it does only warm-up phase after choke has gone off.
And second problem is that it keeps revs up, when it should drop to idle, rpm's stays 1500-2000 for very long time before they drop to idle. I mean long time +30sec.
I have adjusted float level, it was high, but didn't affect, also mixture was adjusted at the same time. Checked and adjusted timing, vacuum hoses has been changed. Fuel pump has been changed, it was leaking, but didn't affect.
So, how can I check these valves?
I took those caps off and the midle one made little "pss" noise, so there were air moving out or in? But those two others didn't make any noise?
If I remember correct, the middle one is controlling throtle actuators vacuum, and if that valve is broken or sticking, it could cause my problems..
