As for the choke, the 7V from the alt may run it, but the weber choke is designed for 12V. If you did the swap, you should have a few 12V key on wires to use for the choke. You did remove all those no longer needed sensors, didnt you?
I used one of those wires that were key on 12V.
I just left the carbon canister (though I suppose that's not a sensor). I shall find a 12V soon enough, no worries. I'm just waiting for those 75 degree days later this week, I'm a sissy.
