Jus baught a 91 efi 5 speed and it has a short some where, the draw is large, everything dims when key is in hot, car wont run when its shorting. No obvious wires, newer alt, newer starter, new coil and ignition components, what could draw enough power to kill everything? , . . 500$ purchase from old man who is second owner with maintenece records, awesome buy in my book.
91 Festiva Electrical short
Start pulling fuses for HOT in RUN to see which circuit the short is on. Start with METER, then WIPER, FAN, DEFOG, HEATER. Good luck doctor J.
You really need an EVTM (Electrical and Vacuum Troubleshooting Manual) for your Festiva.Last edited by bravekozak; 09-09-2013, 08:02 AM.
There is only ten minutes left in this auction. You had better hurry.
You are not online. I will buy this for you and you can Paypal me after.
Just PM me your address so I can tell the seller where to mail it. Believe me, this will be the best ten bucks you will ever spend on your vehicle.Last edited by bravekozak; 09-09-2013, 08:13 AM.
Id like the manuel. Electrical is always fun. Ive never had a car with electrical issues that affwcted everything. Even my dome light flashed when the car died.Yellow 91 festiva GL 5speed
Red 88festiva L 4spd
Blue 91festiva L 5spd (bad tranny, sloppy suspension)
They are a little funky, what is pb blaster? The link housing also looks a little toasty, at some point therehas been an issue in this area. Old owner use to use fuesable link as antitheft system, he would unplug the link at night. Lol, he had the car stolen a couple times in yhe 17yrs he had itYellow 91 festiva GL 5speed
While you have the fusible links out, pop the brass terminals, wire wheel them and then push them back in.Last edited by bravekozak; 09-09-2013, 11:25 AM.
The Kia part mumber is KK14066760 for a new one. Just in case.Last edited by bravekozak; 09-09-2013, 01:43 PM.
Ok, fuseable inks feplaced with solid fuses, pulled all fuses to sub circuits that dont include operation. Short is in a main circuit or relay. Anyone know where to go from here? Im not even sure wherr to begin. New alterntor, new starter, new coil. These replaced by previous.owner within 1yr, dont think they are related to issue. My thought process thinks ignition or relay somewhere but electrical is not my expertise. Any ideas? Also, what is the relay near radiator overflow behind battery? When ever the short happens, it triggers a relay, could just be its taking power away from relay causing circuit to open akd close but im just putting it out thereYellow 91 festiva GL 5speed
Ok, ive done some research and the relay i ws looking at was the main power, what happens if it goes bad? My starter works fine, my spark is cutting in and out, something is grounding. how would i test the relay?Yellow 91 festiva GL 5speed
Ill try bridging it, they dont make the relay anymore either, that sucks. Do you have experience or ideas what my problem is. My thought is to start cutting into the harnesses to find melted wire.Yellow 91 festiva GL 5speed
