Originally posted by koRnhead
91 Festiva Electrical short
Looking at only the schematic for the passive restraint system, it occurs to me that possibly one motor is stuck 'ON'. I don't have that system, but it seems that the mechanism could hang in the track and not reach the cut-off point or, if adjustable, the limit switch could be out of adjustment. This would keep the motor energized. Only one motor energized would not draw enough amperage to blow the 30A fuse, and shouldn't, whereas a dead short to ground will blow any fuse.When I'm good I'm very, very good and when I'm bad I'm HORRID.
The belt is stuck and it i need to free it. Once i get the beast fired up and running thats my next thing to tackle. With the fuse out i can find this other problem. Tooldude, your pretty damn good. I apprecieate someone who knows what they are talkimg about and is on the same page with me.Yellow 91 festiva GL 5speed
Red 88festiva L 4spd
Blue 91festiva L 5spd (bad tranny, sloppy suspension)
I'm sure I'm not the most knowledgeable person on this site regarding Festivas. I just got on a campaign recently to fully understand the Festiva F.I. system. I don't have the answer to everything right off the top of my head like a mechanic who is hands on all the time. Rather, I look at the problem and try to analyze it from theory based on what I've studied and my own experiences, the same way I have to deal with my own vehicles. Anyway, I think your next step is to see that you have voltage getting to your distributor (Y/BK wire) and a signal coming out of it (Y/BL wire). It seems to be the only thing not replaced.When I'm good I'm very, very good and when I'm bad I'm HORRID.
So, i check my batery, it charged over night, 13.6v i reconnect all connectores, fires right up, dies 30sec later, i refire, same thing, then i smell something hot, didnt blow any fuses, wont refire. Main relay is clicking just fine, ill take my mind away from that. Signal to distributer is intermittentYellow 91 festiva GL 5speed
Ohhhh. So i start jiggleing neutral safety and clutch switch and boom fires. What js the switch at clutch pettle that works when pressed in? Not the at rest but at pressed switchYellow 91 festiva GL 5speed
I set a jumper wire, makes no difference. Its starting and dieing after 30 sec. I may have to try this vaf, i have no idea what that could do but damn.
The check for voltage at the distributor was because I thought the car was not starting up again. There is obviously voltage there if it runs at all. The only check there, that makes sense now, would be to see if there is a loss of voltage when the car dies, but the problem is most likely elsewhere. You might check that the connections on the Idle Speed Control Solenoid are tight. There's the possibility that the CKP sensor is faulty. I'm thinking what you are calling spark cutting out is not spark, but a lean miss. Maybe I was taking you too literally. Have you checked all the vacuum hoses thoroughly for hidden splits or loose fitting? You may have a fuel supply problem, that really seems suspect, can you check running fuel pressure? How long since that fuel filter was changed? That's an easy check and probably needs it anyway.When I'm good I'm very, very good and when I'm bad I'm HORRID.
The problem is lean mix. New fuel filter. I checked by sprayibg starter fluid, works every time. My time has been limited, ill start checking vac lines. I wanted to try the VAF, got to jy late.Yellow 91 festiva GL 5speed
Cars running. Grounded out the pcm, started up, kept running, something happened at the pcm, thats why, ignition and fuel did odd things. . . Now on to he new problems and new threads, cilinder head possible crack and really bad slipping clutch. HahahahYellow 91 festiva GL 5speed
