Originally posted by Pu241
White smoke after hard braking...??
Your getting funny and technical. Water vaper goes to break fluid brake fluid doesnt go to water. The different DOT fluids are made for different rubber types and pressure/heats. GM used different rubber mixtures then most imports etc. If you leave patrolium based rubbers in a bath of brake fluid they will deteriorate over time and if you put brake part rubbers in a bath of petrolium oil they will swell larger. Brake fluid has a higher flash point then gas and it will coat your exhaust components. It will make higher condensation in your exhaust output as well. Im sorry i wasnt clear enough before ;-)Yellow 91 festiva GL 5speed
Red 88festiva L 4spd
Blue 91festiva L 5spd (bad tranny, sloppy suspension)
You do realize you are talking to a chemical engineer who specializes in plastics, right? My money says he can tell you the chemical composition of each product you just named, how it is formulated, produced, and used in more applications than you ever dreamed possible, by heart, without reference source other than his brain, with a beer in one hand, and a burger in the other.Originally posted by Jblair View PostYour getting funny and technical. Water vaper goes to break fluid brake fluid doesnt go to water. The different DOT fluids are made for different rubber types and pressure/heats. GM used different rubber mixtures then most imports etc. If you leave patrolium based rubbers in a bath of brake fluid they will deteriorate over time and if you put brake part rubbers in a bath of petrolium oil they will swell larger. Brake fluid has a higher flash point then gas and it will coat your exhaust components. It will make higher condensation in your exhaust output as well. Im sorry i wasnt clear enough before ;-)
No to mention, he is the Right Reverend of Zulu ministries, John bless you, my child!Contact me for information about Festiva Madness!
HHHHHHHMMMMMmmmm I'll go make popcorn, this thread might get interesting....Some people like to read fiction,I prefer to read repair manuals. Weird I know-
OH! I wasn't trying to start anything! PU241 is just an awesome dude
I have my moments, but it is double tough for me to figure things out online. There are a lot of guys on here that are pretty good.Contact me for information about Festiva Madness!
