While digging at the rust, after pulling off allot of the pinch weld that had rotted off the passenger side by the rear wheel arch, and noticed that the slanted metal panel with the holes in it that runs down the length of the inside of the rocker panel is rotted through as well.
How structural is this to the car?
Is it very important? If not I will clean it up the best I can, and then patch up the body around it
Also here is some pics, though one of the pictures is the rear passenger floor pan from the bottom.
