I am about to chew into a new project, replacing the valve cover gasket. I have been leaking oil, mainly down the front just under the cover onto the manifold. I have the Hayes Manual and read it a couple times. As with most how-to manuals, I am sure there are tries and true short cuts and better ways to do it tech out there.
Once I tear into it, is ther anything else that makes sense to change or replace now with the valve cover off? Timing belt tips and tricks?
93 L stock engine
Thanks
David
93 L stock engine
Thanks
David
