Blinkers
  • Blinkers
    My left turn signal flashes faster than the right ,but all bulbs are good and work .
    Any ideas ?
    Donn
    ______________
    93 Blue rio/aspire swapped,B8,
    different load on your left side due to a slightly different bulb in the front or rear. also there could be a mild connection issue (corrosion on the switch) that can change the load side to side. if you replace your flasher unit with an electronic unit, that will "fix" it, as it runs on a timer and not a current load switch. i can change the speed of my turn signals in my cars depending on the wattage of bulbs used (especially noticeable on the Fiero).
      Cool thanks i will check the bulbs and sockets ,I know 1 socket is kinda bad because one of my brake lights fails every so often.
      Donn
      ______________
