different load on your left side due to a slightly different bulb in the front or rear. also there could be a mild connection issue (corrosion on the switch) that can change the load side to side. if you replace your flasher unit with an electronic unit, that will "fix" it, as it runs on a timer and not a current load switch. i can change the speed of my turn signals in my cars depending on the wattage of bulbs used (especially noticeable on the Fiero).
