I'm only getting about 28 mpg down from the 36 I was averaging when I first swapped in the b6. I ran for about 1200 miles no problem, then in a weeks time I developed a miss and started throwing codes. I uploaded a vid awhile back if sparks coming off the ditsy cap at night. Swapped to a new cap changed the plugs and wires and the miss disappeared but I was still getting codes 15 and 17.
I went ahead and exchanged the Bosch o2 I had installed with the new engine for a denso 234-1000 unit, and last week when I was at Bryant's house be forced me to solder the connection lol.. The codes went away and haven't been back.
I'm still getting terrible mileage, and I have no idea why. The car runs fine, I can tell it's lost some power, from 70-90+ it doesn't want to accelerate as fast as it used to.
The temp gauge doesn't climb up to even 1/4. New thermostat with swap too, advance special I remember it said something about it goes wide open if the car tries to overheat but I do t remember details about it.
I've had a high idle this whole time, it's around 2k rpm.
If I'm in first or second gear and go slowly up to around 35/4000 rpm and let off the gas, the car will do a nosedive literally like I just slammed on the brakes and locked up the wheels. Only happens occasionally.
I don't know if any or all if that is related but it's about all I can think of that isn't right with it.
