Well finished my lift 99% today ended up being 7" without tires but i. Found out that the passenger side cv shaft is about 1" short I used a aspire cv for the drivers side and it works so would a passenger aspire cv shaft be longer? If not what other cars would work?
passenger cv shaft too short
Kia Rios are longer, if I've read correctly.White '92 GL 5-speed BP, G series, Aspire/Rio swapped, "Nancy"
1988 LX 5-speed
1993 L 5-speed B8, E series, Aspire/Rio swapped
Gone:
Went to advanced auto parts and looked up the kia rio aspire and festiva cv shafts, the aspire and rio have the same length at 35" but the yoke is like 1" longer then the festiva which is questionable if its long enough1993 festy "white stallion" BP swap with 7" lift, 1ton wench
R.I.P. 1991 festy "the festiva" stock b3, atv bumper, 8' whip
So would it be safe/work if I cut the asire cv in half extend it 1 inch then get a steal pipe use it as a sleave and then weld it? Would the balance be off cuz it would be the center of rotation so I don't think it would be?1993 festy "white stallion" BP swap with 7" lift, 1ton wench
To what I've seen, nothing of your setup is what I'd consider 'safe'. But I really wouldn't go messing with something that holds a lot of weight and allows your car to turn.White '92 GL 5-speed BP, G series, Aspire/Rio swapped, "Nancy"
1988 LX 5-speed
Gone:
Wouldnt It would strengthen it if I use 1/4" steel pipe 35" long that is a snug fit to the cv shaft with welds on both ends? Cuz it would only have a 1" open spot in the middle that would be filled with solid stock but would add 1/2" of the overall diamiter of the cv cuz it would still be stright but thicker1993 festy "white stallion" BP swap with 7" lift, 1ton wench
Why not make aluminum spacers to drop the crossmember say 4", and also an adaptor for the pass. side engine mount? That way you could drop the motor/tranny and keep the CV shafts straighter.Last edited by TominMO; 11-09-2013, 09:22 PM.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Thanks william I had help from movin when I first started my lift but that post helps a lot the aspire abs cv is probably my best bet and if I lower the crossmember to keep my cvs closer to normal then ide loose my 13" of ground clarance which would put me at 9" if I Droped the cross member And have my oil pan exposed which wouldn't be good on rocks1993 festy "white stallion" BP swap with 7" lift, 1ton wench
I also have a gt tranny there axles that would work that are longer?Last edited by Micro Mudder; 11-09-2013, 09:43 PM.1993 festy "white stallion" BP swap with 7" lift, 1ton wench
no don't use a sleeve.the axle would need to be cut at beveled on both ends to where u have a v shape to fill with weld and u need to set all this up in a jig or lathe to get it true to weld. the piece to lengthen it could be cut out of another axle.but in my opinion keep looking for an axle to replace it bc there has to be one long enough somewhere.
Aspire cv is a hair to short cuz when I go in to gear it grabs but also pops out of the yoke so would spacers on the inside of the spendle work or is the aspire cv with ABS a little longer?1993 festy "white stallion" BP swap with 7" lift, 1ton wench
Found a pdf file that lists 1000s of different makes and moddels cvs including length and spine count and the only car that is the right length is a chevy nova from the 80s but is 23 spine tranny side and 24 on the spendle and is 38" long........ the next closest one is the kia rio and aspire but the cv works if I use a 1/4" spacer on the inside of the spendle but my next thang I could posssibly do is lower the passenger motor mount. 1/4" on tos of dropping the suspenshion but if I do I won't be able to drive over top of a 5gal bucket sitting up right.....1993 festy "white stallion" BP swap with 7" lift, 1ton wench
ummm most trucks cant even do that lolOriginally posted by chris (Festiva) View PostFound a pdf file that lists 1000s of different makes and moddels cvs including length and spine count and the only car that is the right length is a chevy nova from the 80s but is 23 spine tranny side and 24 on the spendle and is 38" long........ the next closest one is the kia rio and aspire but the cv works if I use a 1/4" spacer on the inside of the spendle but my next thang I could posssibly do is lower the passenger motor mount. 1/4" on tos of dropping the suspenshion but if I do I won't be able to drive over top of a 5gal bucket sitting up right.....
