Hi; Have a 1991 Kia Pride..Just put new shocks all around and had the rack and pinion rebuilt. There is a squeaking noise when turning left and right and a low speed clunking when going straight. My mechanic has checked everything he can think of out and is left scratching his head.
Specs:
Engine rebuilt last year..New clutch and throw-out bearing..New shocks all around..new rubber on strut "right side"..new CV joints both sides..rebuilt steering (rack showed some wear, replaced plastic bushing)..new bushing sway bar...new bushings shifting linkage..new alt....battery...
Checked every bolt we could find, all seemed good and tight...(noticed when turning steering wheel while parked that the rack applies enough pressure on the firewall that there is a small amount of movement (of the firewall). Firewall seems a little thin to support the torque well....Anyone have any idea what this could be?...thanks
Specs:
