Yea the suzuki swift clutch you got to grind a little bit for it to fit and any clutch now is betther then nothng, so ill probably get the excedy clutch if I can fork up enough to get it and glad I never power shifted and I never will now haha
clutch wont dissinguage?
You also have to drill the new bolt pattern into the flywheel for the Swift clutch. Bad thing was, It was like the 4th time I drove it after getting the exhaust on it. It should be home in a while with a G series complete setup in it. Then I can power shift it without worrying about it.Jerry
Team Lightning
Owner of Team Lightning
93 L Lightning. BP
Ide be too scared to powershift mine still with the cv angles different and the bigger tires cuz I would still break something haha but is your bp turbo? Cuz the point of powershifting is mainly to keepthe turbo at fullboost comming off the clutch into a nother gear or does it work the same without the turbo?1993 festy "white stallion" BP swap with 7" lift, 1ton wench
R.I.P. 1991 festy "the festiva" stock b3, atv bumper, 8' whip
No mines not turbo. I'm used to driving a stock one (a 90 that I bought new) so, I pulled out of my drive and punched it before I thought about what I was doing. Then I heard a "pop" and realized that I had damaged the trans. Now it gets the trans it should have gotten when I started building it. I have 2 complete G series trans and one of them is going into it.Jerry
Team Lightning
93 L Lightning. BP
Yea I kinda did that to my first time thinking b3 power and muscle memory and took off but the clutch sliped a little is what probably saved my tranny but could you pm me for like a parts list to do the g trans swap cuz I know you got to get a special cv for the passenger side but I should have every thang else maybe1993 festy "white stallion" BP swap with 7" lift, 1ton wench
Ordering my clutch soon I'm getting the exedy kit on ebay but does it mater if I get an aspire clutch? And if I do sence they are newer cars would the clutch hold the hp better then a festiva clutch on the same brand?1993 festy "white stallion" BP swap with 7" lift, 1ton wench
nope... same clutch, same holding power.Trees aren't kind to me...
