Its metal and I don't know if it is supposed to go back on with the thermostat or not? Here is a pic of it. Also a pic of the stat that was in my 93 festiva. Is it the original stat? Thanks, Jim
Does this go back on the with the thermostat?
It needs a gasket and you should have put a new one in when changing the thermostat. In your other thread....you mentioned changing the t-stat....did you put a new one in or a used one? What was wrong with the one you have in your pic?"FLTG4LIFE" @FINALLEVEL , "PBH"
