need moral support....
  • need moral support....
    I Can't Make a Festy Run..... and it vexes me SO!.
    i have spark, fuel, compression, timimg is correct. it trys to fire once in a while... it's as if i only have one working injector... in a BATCH FIRE system!?!?!
    :gritteeth::gritteeth::gritteeth:
    I had these same results not long ago and it turns out it was the ten pin plug under the battery . I'm guessing this is a fuel inj car . The pins would make contact every other bit .
    New build on the way .
      I don't believe it for a second! Arty you're a little early for April fools jokes!
        Don't doubt for a minute that you will quickly find the problem... and it will be something simple that we will all want to hear about.
          Plug in the vaf hahahaha
          1989 Ford Mustang GT 5.slow
          1996 Ford F-150
            Oh dang it, I have somehow slipped into an alternate universe where Arty does NOT know all! How do I get back to my regular universe?!?!
              I just had the same sort of problem with my b6t clean all those connectors below washer tank
                yes you can
                -Bryant
                  ok guys... i'll give that a shot, though i should mention that it's an auto (though it shouldn't make much of a differance). the only tool i didn't have with me was a noid light to verify injector signal.
                  the goofy bit about it is that the car was running as it came to a stop light, then it quit (or so i'm told).
                    I know you said you had fuel but did you check the fuel pressure? Possible filter clogged up?
                    Jerry
                    Team Lightning
                    Owner of Team Lightning
                    93 L Lightning. BP
                      thought crossed my mind, but there's usually symptoms that develop before a complete failure. even if the filter would clog, one would think that the engine would fire for a second while the pump is at full bore before the rail bleeds down.... still something to consider.
                        Intermitant CPS signal in the Dizzy?
                          Remember the one we looked at last madness you were at? Have you checked the compression? That one ran until the moment it died, and kept threatening to start...
                            compression with a gauge was not done due to lack of a good battery to crank with. and this was at 7pm on the side of the road.
                              Well crud! Good luck man, I have confidence in your abilities!
                              If that isn't moral support, I don't know what is
                              Don't skimp on the updates!
