Can't Drive
  • #16
    Is the hose a 2" or so diameter silver flex hose? If so, it goes to the filter housing on the carb to heat the air during cold starts in the winter. If not, try to post a pict of the hose for us.
    Jerry
    Team Lightning
    Owner of Team Lightning
    93 L Lightning. BP
    • #17
      It wouldn't hurt to clean the sparkplugs, ignition wires, distributor cap and rotor, at no cost to you, when you have time.
      There are photos and diagrams of the various hoses in old articles in this forum. They can accessed using the search feature. Or, as suggested, post digital photos of your engine showing the hoses in question.
      • #18
        This is the tube. The picture is taken from the right side of the engine bay. IMAG0810.jpgIMAG0811.jpg
        • #19
          Well if you had the air cleaner on there it would be really obvious where that goes, please tell me you are not driving around with the carb open like that... There is a metal box on the side of it that has two fittings for emissions control stuffs
          Oldest Festiva on the forum (so far) 3/87 LX - 225k
          89 Tracer 13" alloys and dome light. Pioneer stereo, all else is stock.
          • #20
            I am wondering about the hose that is a little bit deeper in the engine.
            • #21
              that's part of the PAIR (passive air injection reaction) system, that deeper hose is the other half of the system (it feeds fresh air into the cat, if there's still a cat in the exhaust).
              • #22
                Is it something I need to worry about or can I just turn it yo the side and let it be? When the engine gets warm it does starts to smoke. I will probably be taking the cat off at some point.
                • #23
                  without it working properly, it CAN cause the cat to melt... for the time being, that tube should be capped along with the other tube to help seal the exhaust system.
                  • #24
                    mi, check out the picture in this post.
                    That's what it should look like.
                    Unless you are like me and want to experiment with removing the reed assembly completely.
                    • #25
                      LOL Brave,you've used up your "Link" allotment for this thread. :whip2: (Joke)
                      • #26
                        This may help you
