Didn't see this issue posted anywhere. 88 Festiva, carburetor. Replaced the camshaft oil seal, had timing reset. Now it won't idle when you come to a stop. Before the work was done it was a deal of drive it 5 - 10 miles and it would idle good. Still runs well, but just won't idle. I adjusted the idle speed screw, checked to see if all hoses were attached but still no luck. Am I overlooking something else that should be checked? Thanks
Car won't idle when stopped
got to be fuel or spark. I'd do all standard checks. I keep mentioning ignition control module inside distributor because it's often overlooked. Check as last resort. It has separate circuitry for idle timing. Look at www.ncf.ca/~ag384/Cars.htm.Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
ops: Twisted it in and she idles real fine now. Thanks for the tip, though!
