Weird Burnt Smell very Faint
    Is it not called a fan belt? I guess its the alternator belt? I have no fricking idea. I just know what ever it is its very warn.
      Back in the 60's, 70's and into the 80's they were also called a "fan belt". That belt drove the water pump which also had the cooling fan mounted to the front and the generator/alternator. Most of the young'uns on here probably don't know this.
      Jerry
      Team Lightning
      Owner of Team Lightning
      93 L Lightning. BP
        Matthew, check for wear in the alternator belt. Tightening it is obviously the first thing to do, but depending on how used it is, it may be time for a replacement.
          It is possible that if your squealing does not go away after the first minute or two, that your alternator has bad bearings causing the belt to slip, but really, for less than 10 bucks, throw a new belt on there and tighten to spec and see what happens. If it is constantly slipping you are going to smell burnt rubber eventually.
          Oldest Festiva on the forum (so far) 3/87 LX - 225k
          89 Tracer 13" alloys and dome light. Pioneer stereo, all else is stock.
            I tossed a new belt on and its basically good as new sometimes its just that easy
              Good to hear, and for what its worth. Running studded tires here in Wisconsin is illegal. So dont bother wasting your money.
