I agree bucking is most likely an ignition, not a fuel, problem. I'd start with a good cleaning of the ignition components.
Bucking like it's running out of fuel, then it'll take off!!! ???!??! @$%#$%#$%!!!!
I swapped out the ICM and the other little module on the front side of the coil, no change either time. No condensation inside the cap either. I'm starting to believe its the pump. Like when it gets heat soaked it starts to sputter. I changed the ICM and went on a ten mile drive, it started about 6 miles into the run. Then I swapped the other module and about 2 miles into the run it started acting up.
Tomorrow I'll do a coil swap before a pump swap.Last edited by Larry Hampton; 12-25-2013, 10:13 PM.1963 Fairlane - future NSS drag car
I've done a couple fuel pump jobs lately. Usually they go until they stop. At least that's what I've noticed. Does that truck have 2 tanks. If so what happens when you switch to the other tank to run it?1988 Ford Festiva "Sonic" BPT g25mr MS2 standalone ecu, FOTY '11, Best Beater FMV, Fan Favorite FMVI
1989 Ford Mustang GT 5.slow
1996 Ford F-150
Single tank. I had an '88 with dual tanks. One time the switch stopped working so I thought it was the rear pump. Dropped the tank to find one of the lines disconnected from the check valve. New check valves fixed it.1963 Fairlane - future NSS drag car
No codes. Just not running right.1963 Fairlane - future NSS drag car
Rubber fuel line could be shredding on the inside, cheap fix. My 88 had this issue and i put extra length fuel line to make the fuel line have a swooping motion as opposed to sharp bends. . . If you pcv valve or that dumb little hose near your oil cap leak even a little it has the car run lean, im making new intake now and that sometimes gives my 90 some issues. Those hoses must fit snug. . . My 90 has thrown a CEL for FPR so if there is any issues with the actual delivery system it will usually storr a code. Id try the fuel lines. The idle woud be super up and down if it was an intake leak.Yellow 91 festiva GL 5speed
Red 88festiva L 4spd
Blue 91festiva L 5spd (bad tranny, sloppy suspension)
It wasn't the coil. Checked the plug wires and coil wire. The fuel lines are new with the fuel filter 8 months ago. I don't run ethanol.
I put 6 gallons of fuel in it and it seems to have gone away. Now it started doing this with over a quarter tank.1963 Fairlane - future NSS drag car
I pulled the pump the other day to check for contaminants in the tank, everything looked fine.1963 Fairlane - future NSS drag car
You know, I'm starting to think maybe it's just the filter sock. It was bent in an upwards position. I didn't look closely at the sock itself, but there was some really fine debris in the tank, I'm wondering if the holes in the sock get full of the debris and with the sock pointed up, the fuel can't flow fast enough into the sock, so when I give it more throttle, the sock gets sucked dry at low fuel levels. I'll try replacing the sock after the first of the year at some time when it's warmer on a Saturday.
Obviously I need to pull the tank again and clean it out, which is almost impossible to do.1963 Fairlane - future NSS drag car
You know that there is a drain plug on the bottom of the gas tank, right?
I drained my tank to check things out when I had a problem .... luckly, mine was pretty clean, just some black stuff that looked almost like pepper in there.
I drained tank and siphoned the remaining gas and the black stuff out without removing the tank.Dan
It is alot of work. Not fun dropping the tank. If it were me (and Ive done it) I would spring for an ebay tank. If the tank has any rust issues at all inside, it will continue to rust no matter what. With all the work the work in getting it out I put a new one in mine. I try to justify the cost buy thinking of the money the car has save me.
On a side note, I have a coworker that drives a older gas powered crew cab silverado 50 miles one way to work everyday. I didn't do the math but it has to be between $150-200 a week in gas. Not much left of the paycheck after payin Uncle Sam and Big Oil.'89L 110k mi. BP/G swapped
'90LX 68k mi. wrecked 12/14 RIP
'90 F250 4X4 108K mi.
'13 Kia Rio 5 LX 70k mi.
'18 Kia Soul 40k mi. Daily
'64 Studebaker Gran Turismo Hawk
'66 International Harvester pickup
I know about the drain plug, it's getting the contaminants out is the problem. I just had the tank boiled last spring, so no rust at all. Part of the exterior coating came off and I recoated with some roll-on bedliner.1963 Fairlane - future NSS drag car
