I'm fairly sure it's the alternator, but before I throw money and time at it in the morning, I need to ask.
I found a vacuum leak, and was wrenching to get that fixed. Tuned it, and took it for a test drive. About 4 minutes into my drive, I start hearing a SKREEEECH noise, kinda of like metal-on-metal. I pull over and check, the sound appears to be coming from the alternator. It has a slightly wobbly.. [belt-holder? lol] on it. It's been acting up off and on since I got the car, not seeming to have enough power sometimes, or feeling drained when coming off a high load. But it hasn't failed yet.
If I'm at idle, or not pressing the gas, the noise is very loud. If I give it full load (full pedal), it goes away or gets much less. Turning off all electrics doesn't make it get louder or less.
Alternator, or something else I should check? The belt feels tight.
Also! I have two spare EFI alts, but no spare carb alts.. and this is a carb. I'm about to search, but is there any way to make an EFI work on carb? NEVERMIND, FOUND THIS. I have the Weber choke hooked to 12V elsewhere, so EFI alt will work?
Thank you all!
-Joe
Thank you all!
-Joe
 Thanks anyhooters.
  Thanks anyhooters.
