I don't have the tools to replace bearings, so I think I'll go the easier route of salvaging a hub assembly from one of the Festivas in my local pick-n-pull. In this video, you can see that the hub has some play and spins freely. I'm not sure if it should be spinning this easily... what do you think? http://www.youtube.com/watch?v=-pJ1nzFKBCA
There also happens to be a couple Aspires in a closer pick-n-pull. Should I just go salvage the parts I need from the Aspires or will it be easier to just swap Festy to Festy hub assemblies? My car is a 1990 LX, the one in p-n-p is a '92 L, and the Aspires are both year '94.
