Yesterday fired up the motor after not running for over a month. Motor ran very rough and plumed white smoke. I smelled gasoline. It drove rough and stalled.
Today problem persisted. Hooked up a timing light and found it was impossible to match up the timing mark on the cover to the crank pulley. Also noticed that the light flashed half as many times on #1 as on cylinders 2 & 4. Cylinder 3 is very erratic. 2 & 4 appear to operate normally. Pulled the wire on 1 and noticed a slight decrease in performance. Replaced #1, and pulled wire on 4 and noticed a significant decrease in performance.
Motor idles best (but still not acceptably) with distributor in most clockwise position.
Grounding the STI connector exacerbates the problem.
Pulled timing belt covers and confirmed cam timing is correct.
Tried 2 separate sets of complete cap/rotor/wires and experienced identical results. Plugs are new.
What's my problem? Time for a new distributor?
