First off, I used the search and came up nil.
So, I am looking for a way to renew the seals inside the climate control box (or whatever it is called). All of my moving parts move correctly the mixer mixes, however the seals are not sealing and I think a bit of the ducting is either cracked or disconnected.
I am aware about the no heat from the center vents, one of the problems is that those vents leak by cold air all of the time.
Anyone have info on this? Would like a diagram or pictures, or just some friendly advice before I go poking around where I don't belong.
Thanks!
Thanks!
