b3 engine - Can the oil filter threaded nipple be removed?
  • b3 engine - Can the oil filter threaded nipple be removed?
    I read that on other mazda engines, the 2.2 and v6's for example, this piece that is threaded into the block can be removed. The owners then have the option of adding a jeep piece that converts metric to the chrysler. I tried with a rag+pliers halfhearted on my spare b3 but didn't heat it up or pb blaster it first or anything, for about 10 seconds i tried but I didn't want to damage the threads. REASON: i have two different high dollar oil coolers that are dodge/toyota/ford application so it would be nice to either implement one of those, or be able to use the 20+ oil filers I've hoarded. I dont own anything else with honda/mazda oil filter threads anymore.
    1993 GL 5 speed
    I think it's got a Allen wrench hex inside? I know one if the b series does anyway can't remember if it was b3 or Bp..?
    2008 Kia Rio- new beater
    1993 Festiva- Fiona, DD
    1997 Aspire- Babyspire, DD
    1994 Aspire - Project Kiazord
    1994 Aspire- Crustyspire, RIP
      I used vice grips, but I was trashing it anyway. It did work, though.
        Yes !! I have installed bp oil coolers on b3 engines !
        New build on the way .
          and he has spoken
