Well instead of working through things with a test light like I should have.... After days of pulling my hair out and wondering why my fuel pump was not getting power... ( I wasn't aware of the jumper thermals under the hood at the time) I decided to take the pump out... It worked fine... I was getting frustrated so I ran a 12v wire to a switch and wired it into the fuel pump harness... I flipped the switch on and it worked fr a min... Then the pump area started smokin... I pulled the pump again... I didn't fry the pump... But my question is does anyone have a idea what else might be fried??? Because now if you try to start it, it blows the disable links... Any help would be greatly appreciated!
Fuel circuit short
What you are describing is a short to ground. There is a bare wire touching the body somewhere in the harness. If it is melting the fusible link. then you will have to inspect the wire colors in that circuit. What year is your car? Check your main relay behind your left headlight, Check your fuel pump relay under your dash where the antenna enters the car.Last edited by bravekozak; 01-19-2014, 03:58 PM.
You should have re-terminated using CNA .250" tang less open barrel terminals and pushed them into the connectors until they clicked in place. It sounds as though they are touching. Unplug them spread them apart and see if the fusible links burn out while you are cranking. If they don't, then that's your problem. Also test to make sure you have power to both the red wire (fuel level) and the black/white stripe wire (fuel pump power) with a 12V test light.Last edited by bravekozak; 01-19-2014, 05:12 PM.
Bean, everything that I highlight in blue is a hyperlink. Please follow. Actually, everybody who has a Festiva should have $20 woth of these terminals. I suggest a variety. 25% thin gauge wire, 50% medium gauge, and 25% thick gauge. You may reuse your existing connectors if you learn how to release the terminals out of them.
I would also recommend buying some open barrel splices in both sizes.
As an afterthought, you may want to buy a couple of .312 terminals as well. I found them to be invaluable when the wire just broke off from the back of my connector to the starter motor. I needed both sizes. One thick, and one thin. They saved my bacon. Also another wire that is .312 is the brown AMP connector on the back of the factory radio. That one has a tang! That broke on me too. I just smiled. No problemo.
I would select a couple of 6mm (for ground straps) and 5mm ring terminals also (if you have a carb ignition coil)Last edited by bravekozak; 01-19-2014, 06:57 PM.
Check the wiring harness for signs of burning or melting. The problem is going to be that the Mazda harnesses are all wrapped in tape. They did not use split loom. Start with the main relay and work your way back. I always pull all the fusible links at the junkyard, just in case I have to troubleshoot someone's electrical problem.
I just did what the other forum members suggested and installed a pink, a green and a pink.Last edited by bravekozak; 01-19-2014, 08:34 PM.
