ECU/ECM Question
  • ECU/ECM Question
    Can some one tell me is the ECU/ECM
    on a Festiva Automatic a 2 plug and the
    Manual is a 3 plug or is it the other way.
    Thank You
    WTH
    92 GL was red automatic Ms Va., now Zinc Yellow
    My auto is 3 plug, my 93 manual is 2 plug, YMMV. If you need to know for your car, and it is accessible, you can see the plugs by looking under the dash. For reference, if you take the drivers side front speaker grille and speaker(if there is one) you can see the top of the ECU. Look under the dash in the same spot, and you see the two or three) big connectors sort of behind the fuse box.
    My auto is 89. Let me say, I have an ECU labeled automatic that I picked up a while back here in the house that is 3 plug, and IIRC my 89 is 3 plug. I Guarantee my 93 is 2 plug.
      Scitzz
      Thank you for that information had them
      Labelled and someone remove the labels.
      Wth
        Ahhh, I getcha
        Sharpie FTW!
          ALL the 90 and newer are 2 plug (auto or manual). The 89 auto is the 3 plug.
          -Greg
          Redneck Engineer
          FOTY - '09
            The 89 auto is the odd ball. all 90+ ECUs are the same (as Greg said). The carb'd "ECUs" are the same and are 3 plug. If you have an 89 auto you need an 89 auto ECU, which is also 3 plug but not the same as carb ECU (naturally!).
            ~Nate
            Current cars:
            FOTY 2008 winner!
